Mathematical OperationsThe Mathematical Operations action task resolves a mathematical expression and stores the result in an existing Job Information or other type of variable (see About variables). When adding this task to your process, you will be asked if you want to add the task as an Action or a Condition. This task should only be used as an Action. If used as a condition, it will always return False. The task does not modify the job file in any way, its only output is the change in the specified variable where the result is stored. InputAny active data file, in any format. This data file is ignored by the task and is not modified in any way. ProcessingThe task executes the mathematical operation and stores the result in the selected job info or variable. OutputThe input data file is returned with no modifications. Metadata is not modified. A single job info or variable is modified by this task. Task propertiesGeneral Tab
This task was built using a custom plugin system and does not display the On Error tab in the regular view. To access the On Error tab, right-click on the task and select Advanced Properties... |
