Metadata File ManagementThe Metadata File Management action task is used to execute actions on Metadata files. This task does not modify the data, Job Info variables, other variables or any other part of your process. For more information about Metadata see Metadata. InputThis task takes any file as input and does not modify it. ProcessThis task does not execute any change to the process, its files or variables. It only executes the selected action on Metadata. OutputThis task outputs the exact same data that was given to it. Its Metadata will either be missing (Delete Metadata), Changed (Load Metadata) or the same (Save Metadata). Properties
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
