Metadata Filter
The Metadata Filter task allows specifying the Level (Group, Document and Datapage) on which to perform the action and under which condition. At least one level must have the condition set. The action will be performed sequentially beginning with the rule on the Group level, Document level and Data page level. The selection is performed on the node only.
For more information about Metadata see Metadata.
Any data file with accompanying Metadata.
Any Metadata that does not correspond to the rules set forth by the filter are removed from the active Metadata. Note that the 'removed' Metadata is still present in the file, but is disabled and ignored on all tasks that use Metadata afterward.
The original data file is output, along with the modified Metadata.
  • Filter levels: Rules for deselecting nodes at the Group, Document or Data page level. Note that currently unselected nodes are ignored.
    • Group: Select the Metadata Group nodes (the nodes only) based on the specified rule(s).
    • Document: Select the Metadata Document nodes (the nodes only) based on the specified rule(s).
    • Datapage: Select the Metadata Datapage nodes (the nodes only) based on the specified rule(s).
  • Rules: Define according to which criteria the action must to be performed. The condition must be TRUE to execute the action. All nodes on a specific level with false condition become unselected. The task effectively both selects and deselects nodes based on the condition. To set up conditions, the Rule Interface is displayed, allowing to edit the condition for the given action. See the Rule Interface page for more details.
  • Select all Metadata nodes: Check to reset the Selection status of all nodes before performing the filtering, effectively selecting all metadata nodes. This basically undoes the work of any previous Metadata Filter or Metadata Sequencer, so be careful when using this option.
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
Special Considerations
  • The task CANNOT re-select unselected nodes if the condition is false for those nodes.
  • Filter rules cannot be based on the following metadata attributes: SelectedIndexInJob, SelectedIndexInGroup, SelectedIndexInDocument and SelectedIndex.
  • Last Topic Update: Aug-20-2018 - 10:08
