Metadata Level CreationThe Metadata Level Creation task conditionally creates new Metadata groups or documents. This task is only functional if Metadata already exists for the current job. For more information about Metadata see Metadata. The task enables users to merge data pages into Documents and/or merge Documents into Groups, based on conditions. Unselected Data pages are ignored, but are moved with other Data pages if the action is applied to the current parent node. Using the wildcard parameter "?"Since all metadata data pages, and possibly all physical data pages, are treated by the task at run-time in order to evaluate the condition at each level, it is necessary to dynamically define metadata as well as data selections to check all occurrences instead of a fixed one. Example of a process with the Metadata Level Creation taskGiven a document input (created with Metadata), this task can be used to regroup the PDF pages of the received print stream in logical (Metadata) documents, based on the keyword “Page 1 of” printed on the pages, and then treat each newly created document individually in the rest of the process The process begins with the following tasks:
With this example, before the Metadata Level Creation task, the Metadata structure contains one group containing one document (containing multiple data pages). After the Metadata Level Creation task, the Metadata structure contains one group containing multiple documents. InputAny data file with accompanying Metadata. ProcessingThe Metadata file is split on the selected level. OutputThe original data file is output, along with the modified Metadata. Task propertiesGeneral Tab
Attributes and Fields are deleted for all new Group levels created.
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
