Metadata SorterThe Metadata Sorter action task allows Metadata to be sorted sequentially on three different levels, alphabetically or numerically. It also allows sorting in ascending and descending order. For more information about Metadata see Metadata. InputAny data file with accompanying Metadata. ProcessingThe order of the Metadata is changed in accordance with the rules set forth in the task's properties. OutputThe original data file is output, along with the modified Metadata. General Tab
For each parameter, three columns are available: Sort By, Then by, Then by (again). This lets you sort your document level in three different orders sequentially. Sorts are always done from left to right, top to bottom, giving you a total of 9 sorting possibilities. When you click on either of the sort boxes, a small pop-up displays the following options:
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
