Job ProcessorThe Job Processor plugin is an output plugin that appears in the Plug-in Bar of Workflow under OL Connect Send. InputThe Job Processor plugin must be added to a Workflow job transfer process that starts with an HTTP Server Input. The Job Processor plugin is the only other task in that process. It is strongly recommended that a single job transfer process for all OL Connect Send Printer Drivers is created, using the domain or machine’s or user information to divert to any follow-up processes.
This single transfer process can be set to "Self Replicating", so that parallelization is possible. ProcessingThe Job Processor plugin receives a compressed PostScript file sent by the OL Connect Send Printer Driver and communicates with the Printer Driver to ensure that all data has been received correctly. If the Printer Driver has split the job into multiple chunks, the plugin combines the chunks into one PostScript file. License modeEach incoming print job is checked against the license to determine if it can be handled in licensed mode or in unlicensed mode. If OL Connect Send is unlicensed, the plugin stores the incoming job in the target folder using the specified file name, but it does not save any information in the database. The end user will receive a message in the Notification Area (also called "system tray") confirming the unlicensed status, and the printer driver will not request another web page. In licensed mode, the plugin will store all relevant information about each job in the OL Connect Send database. This database is a HSQLDB and is installed automatically. Subsequent Workflow processes can use the information in the database for additional processing (see Get Job Data). Whether OL Connect Send is licensed can be seen on the General tab of the properties dialog. TimeoutDuring a job transfer from the OL Connect Send Printer Driver to Workflow, a timeout could occur (indicated by a log entry like “ERROR: sendBinaryContents: Could not open request. Reason: 12002”). In this case, the timeout for the HTTP service in Workflow needs to be increased. It is recommended to use a value of more than 10 minutes (>600 seconds).
SecurityIn order to provide security when printing over the internet, OL Connect Send includes several protective features. HTTPS CommunicationThe OL Connect Send Printer Driver can be set to use HTTPS for any job transfer. To do this, Workflow must also be set to use HTTPS. Job OriginEach print job will include unique information about the machine it has been sent from. This unique machine ID is calculated with a proven method and will be transferred, encrypted and enhanced. The enhancement will result in a different encrypted machine ID per print job, so that spoofing can be detected. On the server side, if spoofing is detected a respective message will be created. Database connectionThe Job Processor plugin works with a database to store all relevant job information. This database is a HyperSQL Database (HSQLDB, see https://en.wikipedia.org/wiki/HSQL_Database_Engine). It is installed as a service with the name OL Connect Send DBServer (the internal service name is OLCSServer). Communication between the plugin and the database occurs using port 9001 (the default port for HSQLDB). However, there may be situations where this port is already blocked by another application and may need to be changed. OutputThe plugin stores the incoming print job in the target folder with the file name specified in the plugin. MetadataIn addition to the print job, the plugin creates a metadata file with basic information. The values originate from the client machine. PropertiesGeneral tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
