| All In OneThe All In One task extracts data from the job file, merges the data with a Connect Designer template, and creates print output. (See also: OL Connect print jobs.) This task is a combination of 4 different OL Connect tasks within a single one. This makes creating Print content easier and faster, as the task is optimized for this specific purpose. It exchanges less data with the server than the separate plugins do and it has multi-threading support: it can produce the data set and content items in parallel. The task is build with 3 tabs that represent the 3 main steps of the creation of a Print Output: Data Mapping, Content Creation and Output Creation.In a Print process built with separate plugins, the Job Creation task comes between Content Creation and Output Creation. With the All In One, Job Creation is implied and equivalent to a single created job; it isn't possible to use a Job Preset.
 If you do need to use a Job Preset, set the All-In-One’s Output Creation options to None. Add the Job Creation and Output Creation tasks to the process after the All-In-One. This task can be added as an Action task (see Action Tasks) or as an Output task (see Output Tasks). Adding it as an Action task enables the process or branch to continue after this task. An Output task is always located at the end of a process or branch.  When added as an Output task, the All In One plugin works asynchronously to the Workflow process. Task propertiesData Mapper TabThe Data Mapper tab generates a Record Set from a specific source: data mapping on the appropriate source (Current Data File, Database or PDF/VT data file), Retrieving items from the Connect Database (filter setting) or uses the current job Metadata. The resulting Record Set is given to the Content Creation part of the task. In order to optimize the process, blocks of 100 records are sent sequentially to the Content Creation in parallel, instead of waiting for the whole record set to be created.
                                            Source: Indicates the source of the Record Set metadata: Content Creation TabThe Content Creation tab generates Content Items either by merging a Record Set with a Template, or by processing a PDF/VT file into individual content items.
                                            Template: Select the appropriate template or option to execute it:"None" filename: Select to skip Content Creation completely."%o": Select to use a dynamic template name. Click on %o to change the expression that determines the name of the template to use.Template Names: Select the appropriate template name from the list. Adding templates is done from the Send to Workflow option in the Designer Module.
Preview: Displays a preview of the output generated by the Print context of the selected Template. Not available for the PDF/VT or dynamic template names. By default the entire Print context is printed. Printing selected Print sections can only be achieved with a Control Script in the template (see Control Scripts in the Designer Help). Output Creation TabThe Output Creation tab generates the output for the current job, using the selected Output Creation Preset. Note that the Job Creation task normally necessary when using the individual tasks is implicitly executed before output creation.
                                            Output Preset: Select the appropriate Output Creation Preset to use:"None": Select to prevent the execution of Output Creation. In this case the All In One can be combined with the Create Job and Create Output tasks and thus also with a Job Preset and Output Preset."%o": Select to use a dynamic Preset name. Click on %o to change the expression that determines the name of the Preset to use.Preset Name: Select the appropriate Preset to create output with. Adding Output Creation Presets is done from the Sent to Workflow option in the Designer Module.
 OL Connect Proxy TabThis tab is common to all OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences.  Defaults are not used unless the configuration is sent to the Workflow service.
                                            OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340User name: Enter the user name expected by the OL Connect Server.Password: Enter the password expected by the OL Connect Server for the above user name. On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
