PrintShop Web ConnectThe PrintShop Web Connect Input task allows the use of a PlanetPress Workflow in order to drive PrintShop Mail Web requests. A Send to PlanetPress printer is available to PrintShop Mail Web operators selecting Generate Output in the PrintShop Mail Web Order Manager, providing an easy way to send jobs toward the PrintShop Web Connect Input task, in order to take full advantage of PlanetPress Workflow's built-in automation tasks. PrintShop Mail Web and PlanetPress Workflow must be installed on the same server in order to make the PrintShop Web Connect Input task available in your PlanetPress Workflow.
InputThis task does not poll an input, it sits there and waits for a job file to be sent by the local PrintShop Mail Web installation. ProcessingWhen the job is received from PrintShop Mail Web, it is saved as a job file. No further processing is done on the file. OutputThe task outputs the job file as is, with no evaluation or modification. The format of the job is PostScript generated by PrintShop Mail Web. PrintShop Web Connect PreferencesA PrintShop Web Connect preferences page, accessible via the PlanetPress Workflow Button | Preferences | PrintShop Web Connect, allows to provide operator credentials to your PlanetPress Workflow configuration. It is also mandatory to send your configuration to your PlanetPress Workflow service since the PrintShop Web credentials are included in the *.cfg file (See Sending a configuration), which is updated every time the configuration is sent to the service via the Send Configuration button.
"Other" Tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
