Search and ReplaceSearch and Replace Action tasks are used to locate and replace strings of data within the job file and to replace them with other strings of data. Note that this Action task cannot be used with binary files. For more advanced search and replace functionality, see Advanced Search and Replace. InputAny text-based file can be used in this task, even formats that are not directly compatible with PlanetPress. As long as the text is visible in a text-based editor (such as Notepad), it is readable and supported by this task. ProcessingThe appropriate changes are made to the data file (replacing text). OutputThe modified data file is output from this task. Metadata is not modified in any way if it is present. Task propertiesGeneral Tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
