Serial InputSerial Input tasks receive files sent to a serial port on the computer running PlanetPress Workflow. All the Serial Input tasks in a PlanetPress Workflow configuration share the same general properties, which are configured through user options (see Serial Input plugin preferences). Only the properties set in the Other and Error tabs are specific to individual tasks. InputThis task does not poll an input, it sits there and waits for a job file to be sent through the Serial connection. ProcessingWhen the job is received through the Serial connection, it is saved as a job file. No further processing is done on the file. OutputThe task outputs the job file as is, with no evaluation or modification. Task propertiesGeneral Tab
"Other" Tab
Job Information definitions
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
