Set Job Infos and VariablesAdd Set Job Infos and Variables action tasks to set Job Info elements as well as custom variables (see About variables). You can set multiple variables and Job Info values in a single task. Be aware that lines are processed from top to bottom. InputAny data file in any format. ProcessingThis task assigns the defined values to local or global variables or Job Info variables. It does not modify the data file nor the Metadata. OutputThe original data file, Metadata and other Job Info variables are not modified, they are passed on to the next task. Task propertiesGeneral Tab
On Error TabComments TabThe Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane. Check the option Use as step description to display the text next to the icon of the plugin in the Process area. |
