A process is a single workflow within the configuration. A process begins with a single input task, contains one or more tasks and/or branches, and terminates with one or more output tasks. In its simplest form, a process can simply retrieve data from a given folder and save it in a different folder. In most cases, though, processes are more elaborate and configurations, which may include many processes, can be extremely complex.
The available processes in your PlanetPress Workflow Configuration are listed in the The Configuration Components Pane. Processes in a configuration will always run concurrently. You can schedule processes to run only at certain times or intervals (see Access Process Properties).
There are three types of processes available to you:
Regular and startup processes can be set to be Active (process runs normally) or Inactive (process will not run at all). An inactive process will display in the Configuration components as red and strike-through. Inactive processes can be useful for designing new processes in a live configuration, since the process does not execute there is no danger is submitting it to aPlanetPress Workflow Service.
