When a user opens a session on a computer, they typically need to login. When they do so, a session is opened and customized for them on that computer (certain drive letters and network shortcuts may be mapped, local and network printers may be made available, etc.). Furthermore, local and network rights may be granted to them. The right to get documents from—and to put documents in—local or network folders, for example, or the right to print on such or such printer.
Programs, such as PlanetPress Workflowand all their services, must identify themselves in order to be granted permission to perform operations on the computer on which they run as well as on other computers accessible via a network connection. On a given workstation, you can configure your PlanetPress Workflowto use either the local system account or any specific user account (refer to “Choose the Account to be Used by PlanetPress Workflow”). When you do this, you grant the PlanetPress Workflowand all its services the same rights associated with the selected account (this is true of all services with the exception of the PlanetPress Suite Messenger which always uses the local system account). It is important to note that PlanetPress Workflowand its services require administrator rights to run on any given computer and that they must therefore be associated with an account that as such rights.
When you are running the PlanetPress WorkflowConfiguration program on a workstation, if it is associated with an account that is different from your account, the following icon is displayed in the lower right corner of the PlanetPress WorkflowConfiguration program: . This is to draw your attention to the fact that your PlanetPress Workflowmay have rights that differ from your rights, and that this application and its services may therefore not be able to perform some of the actions you can perform when you create or edit a given configuration.
The simplest thing to ensure that rights are the same across your whole network is to create an administrator network account especially for PlanetPress Suite Workflow Tools. This will ensure that the PlanetPress Workflowand all its services have the same rights on all computers and that it is therefore able to perform all the actions defined it needs to on every computer on your network. A less permissive solution is to create an administrator local account for the PlanetPress Workflowand to replicate it on each computer where PlanetPress Workflowand its services are likely to perform operations, such as get files, store files, or run applications and perform operations.
Different users may create different printer queues. Let us say you have a big HP printer in your office. User A creates a printer queue on his system called “Big HP” for that printer, and user B creates one called “My printer” for the same printer. A configuration created on user A’s system and than used on user B’s system would generate errors trying to print to the “Big HP” printer queue.
Different users may also map network drives differently. Let us say this time that you have a server in your office. User A maps that server’s main drive using drive letter “y:” while user B maps it using drive letter “z:” A configuration created on one system and than used on the other would both get and save the wrong files from the wrong drives. Note that such situations may be avoided by using the Universal Naming Convention option.
PlanetPress Workflowconfigurations are not user specific as such. If you make sure that all the user accounts have adequate network rights, that printer queues are defined the same way on all systems, and that all network drives are mapped using the same drive letters (or that the UNC option is selected in the network options), then you should have no problems running configurations on different systems using different user accounts.
