8.17.52015-05-05
Create File
Create File input tasks are different from other input tasks in that they do not pull in data from a source location. The data that this task passes along to other task is its own: text or values from variables entered when the task was created or last edited.
Since Create File input tasks are not dependent on data from external sources, they are performed at every polling interval and the process is thus started every time.
Create File does not capture any file and, if it is a secondary input task, discards the current data file.
Create File generates a job file with the contents of it's text. If variables and control characters are present, they are evaluated at runtime when the task is executed.
The output is the job file. No metadata is generated by the task itself, however if metadata is present in the job and it is not deleted (in the "Other" tab), it will remain active.
Create File input task property is as follows:
"Other" Tab
Job Information definitions
Examples & Use Cases
Common Errors
Comments Tab
