8.17.52015-05-05
WinQueue Input
WinQueue input tasks capture print jobs received by a Windows printer queue.
Before you go through the following procedure, on the computer running PlanetPress Workflow you will need to create a local printer queue that will be used to receive data files in the form of print jobs. This queue can be shared, so as to be able to receive jobs sent from local as well as remote users.
To ensure that the spooled files created by PlanetPress Workflow queue remain in the spool folder, the printer queue must be paused.
The WinQueue input regularly polls the selected printer queue for new jobs. When a new job is available, it is captured automatically by this task.
The print job, by default, is in EMF format. If this option is selected, no action is taken on the data file. However, if the RAW format is selected, the job is converted to RAW. Furthermore, if the Create PDF option is selected, the file is converted to a PDF, including metadata.
PDF Output is part of the PDF Tools group, which is only available in PlanetPress Office and PlanetPress Production.If it is used in PlanetPress Watch, a watermark will always appear in the PDF created by this task.
Either one of 3 formats is output from this task:
WinQueue input task property is as follows:
General tab
"Other" Tab
Job Information definitions
Common Errors
Comments Tab
