8.17.52015-05-05
PlanetPress Fax
PlanetPress Fax output tasks are used to make request to PlanetPress Fax, which creates faxes and sends them to a faxing program.
In addition to the job-specific PlanetPress Fax properties you configure in the task’s properties dialog box, there are configurable options common to all PlanetPress Fax outputs processed by a given computer (see PlanetPress Fax User Options). Note that those options are specific to each PlanetPress Fax installation and that they are immediately applied.
Any data file with a valid Emulation. Metadata is optional and can be used to specify the fax number and information to send the file. Alternatively, a TIFF file in the proper page size and compression (CCITT Group 4) can be used.
If a data file with metadata is used, the data file is merged with the selected PlanetPress Design document, converted into a multi-page TIFF file with CCITT Group 4 compression, and sent to the PlanetPress Fax host specified in the properties. If the file is a TIFF file in the proper format and the "Passthrough" option is selected, no processing is done, the file is sent as-is.
A TIFF in the CCITT Group 4 compression, and information for the FAX server to know where to send the file.
Task Properties
General tab
