8.17.52015-05-05
Add Document
The Add Document action task prepares a printer-centric PostScript job by adding a PostScript version of a selected PlanetPress Document and the trigger to execute it before the active data file.
This task can support files in any emulation, however, the actual file that should be used is one that is compatible with the selected PlanetPress Design document.
This task takes the PostScript version of the document (.ps7), ads the trigger and then the active data file to it. If metadata is present, the output is based on this metadata (unselected data pages will not generate output, the sort order will be respected, etc). Otherwise the complete data file is merged.
The output is an PostScript job that can be sent to any output task in "passthrough" mode, for example Create PDF, PlanetPress Image, etc. Metadata is not generated by this task.
Add Document action task properties are as follows:
General tab
Common Errors
Comments Tab
