8.17.52015-05-05
Download to Printer
Download to Printer action tasks are used to warn printers that the files that will be sent to them are to be stored to a specific location rather than printed. Note that each Download to Printer action task must be followed by a Printer Queue output task set to "passthrough", in order for it to be sent to the printer and not merged with a document.
You can use Download to Printer action tasks to send various types of files, such as attachments, documents and fonts that are used in PlanetPress Design documents that are executed directly on the printers.
For images you should rather use Send Images to Printer action tasks (see Send Images to Printer), as they provide image quality and conversion options.
Any file that you wish to upload to the printer. Note that this task does not attempt to verify that the type of file being sent is compatible with the printer, or is in a supported file format.
The currently active data file is converted into postscript.
A postscript file containing the necessary code to save the data file on the hard drive.
Download to Printer action task properties are as follows:
General tab
Common Errors
Comments Tab
