8.17.52015-05-05
Run Script
Run Script tasks are used to run scripts that typically perform some kind of processing on the job file received by the task. Scripts are often simpler to write than programs added with the External Program action (see External Program). However, they can be slower to execute.
The Run Script action task can be used either as an action or a condition. When dragging and dropping a Run Script action task on a given process, you select whether to use this task as an action or a condition from a contextual menu.
For more information on scripts, what languages are supported and how to write scripts and conditions, please see the related chapter, Using Scripts.
Any data file, in any format.
The script is executed. The script can modify anything such as the data file, job infos, metadata, or even other files on the operating system.
Whatever file the Run Script action generates, metadata it modifies or creates, etc.
Note about conditions: When using Run Script as a condition, the output of the task can be within the branch or on the main trunk. To control the output, use the Script.ReturnValue variable in your script.
Run Script action task properties are as follows:
The Script Editor menu options are as followed:
The other options of the window are:
With the Run Script action, the On Error tab is accessible by right-clicking on the action in your process and clicking Advanced Properties.
The On Error tab will be triggered if your script has an execution error (such as syntax error, etc) as well as when raising an error from wtihin your script. For more information, see
Common Errors
Comments Tab
