8.17.52015-05-05
Set Job Infos and Variables
Add Set Job Infos and Variable action tasks to set job info elements as well as custom variables. You can set multiple variables and job info values in a single task. Be aware that lines are processed from top to bottom.
Any data file in any format.
This task assigns the defined values to each local or global variables or job informations. It does not modify the data file nor the metadata.
The original data file, metadata and job infos are not modified, they are passed on to the next task.
Set Job Infos and Variables action task properties are as follows:
General tab
Common Errors
Comments Tab
