8.17.52015-05-05
File Size Condition
File Size conditions test the size of the job file they receive. Note that the job file may include data selections, attachments and documents that were added by other tasks. If a file does not exist, it's file size will be 0kb.
File Size Condition properties are as follows:
General tab
Examples & Use Cases
Common Errors
Comments Tab
