8.17.52015-05-05
Input Error Bin
The Input Error Bin Task is used specifically and only to create error management processes. These processes do not run on their own but are rather triggered by the "On Error" tab of tasks in other processes, when that task fails.
This task receives a data file from a task that generated an error. Accompanying this data file is the current Job Infos of the process that triggered the error. This means that this input does not generate its own job infos!
No Metadata is received by this task, and none is generated.
The following error information is generated by the Input Error Bin starting version 7.5, and is accessible throughout the process:
No processing is done by this task.
The output of this task is the same as the input - a data file and job infos that are sent from a task that generated an error.
"Other" Tab
Job Information definitions
Common Errors
Comments Tab
