PlanetPress Workflow scripting offers a number of methods of communicating with your process by means of PlanetPress Workflow automation object's methods and functions. The automation object is available in all 4 languages through their own syntax - the examples provided here are for VBScript.
While the functions here are in mixed case to simplify reading, it's important to note that some languages (especially Javascript) are case-sensitive and will require the proper case. Examples in this chapter will always use the proper case when relevant.
Here is a list of the methods and functions that are available to you through the automation object (or "Watch" object). While these examples are all in VBScript, you can click on any variable name to open a page to see examples for each supported language.
| Variable Name | Description |
| Example Usage (VBScript) | |
| Watch.GetJobFileName | Retrieves a string containing the job path and filename located in the job spool folder. |
| Example Usage: | str = Watch.getjobfilename |
| Watch.GetOriginalFileName | Retrieves a string containing the job's original path and filename. Note: this filename is generally no longer available if it has been captured by Watch. |
| Example Usage: | str = Watch.getoriginalfilename |
| Watch.GetMetadataFilename | Retrieves a string containing the job's metadata path and filename. This is useful when using the Metadata API in your script. |
| Example Usage: | str = Watch.getmetadatafilename |
| Watch.GetJobInfo | Retrieves the content of a numbered job info (%1 to %9). |
| Example Usage: | str = Watch.getjobinfo(9) |
| Watch.GetVariable | Retrieves the content of a local or global variable by name. |
| Example Usage: | str = Watch.getvariable("Varname") |
| Watch.ExpandString | Retrieves the content of any Workflow string, containing any variable available to Watch, including data selections. |
| Example Usage: | watchDate = Watch.expandstring("%y-%m-%d") |
| Watch.Log | Writes to the Workflow log file, or the message window when in debug - can accept multiple log levels from 1 (red) to 4 (gray). |
| Example Usage: | Watch.log "Hello, World!",1 |
| Watch.ShowMessage | Displays a popup dialog box to the user (user has to be logged on). |
| Example Usage: | Watch.showmessage("Hello, World!") |
| Watch.InputBox | Prompts the user for a string and returns the value (will not work when running as a service) |
| Example Usage: | str = Watch.inputbox("Caption","Message","default") |
| Watch.SetJobInfo | Writes the value of a string to a numbered job info. |
| Example Usage: | Watch.setjobinfo 9, "String" |
| Watch.SetVariable | Writes the value of a string to a local or global variable by name. |
| Example Usage: | Watch.setvariable "global.GlobalVar", "Hello World!" |
| Watch.Sleep | Pauses all processing for X milliseconds. |
| Example Usage: | Watch.sleep(1000) |
| Watch.ExecuteExternalProgram | Calls and executes an external program in the command line. |
| Example Usage: | Watch.executeexternalprogram "del *.ps" "c:\" 0 true |
| Script.ReturnValue | Returns a boolean True or False value to a Workflow scripted condition |
| Example Usage: |
Script.returnvalue = 1 |
| Watch.GetPDFEditObject | Is used to manipulate PDF files using the AlambicEdit API. |
See the AlambicEdit API for more information. |
