8.17.52015-05-05
Load External File
Load External File Action tasks are used to replace the current job file by the designated text file. Loading an external file does not delete the original file or modify it in any way.
The current data file in the process will be discarded.
The external file specified in the task's properties is loaded and replaces the current data file.
The loaded file is output. Metadata is not modified in any way, neither are job infos.
Load External File action task properties are as follows:
General tab
Examples & Use Cases
Common Errors
Comments Tab
