8.17.52015-05-05
Metadata Sequencer
Although the Metadata Sequencer acts as a splitter, the data file itself remains untouched, as neither the data nor the metadata are actually being split through this task. With each sequence, the entire data file still gets carried from one task to another. Metadata records are simply selected/unselected, which has the same effect.
Any data file with accompanying metadata.
A loop is established and the metadata is separated into chunks, as defined in the rules set forth in the task properties.
The original data file is output once per chunk, along with this chunk's metadata. Note that *all* the metadata is in each of the sequence, but anything not part of the sequence is disabled and is ignored by all tasks using metadata afterwards.
Task Properties
