8.17.52015-05-05
Metadata Level Creation
Conditionally create new metadata groups or documents. This task is only functional if metadata already exists for the current job.
The task enables users to merge data pages into Documents and/or merge Documents into Groups, based on conditions. Unselected Data pages are ignored, but are moved with others Data pages if the action is applied to the current parent node.
Any data file with accompanying metadata.
The metadata file is split on the selected level.
The original data file is output, along with the modified metadata.
Task Properties
Common Errors
Comments Tab
