8.17.52015-05-05
Metadata Sorter
The Metadata Sorter Action task allows metadata to be sorted sequentially on three different levels, alphabetically or numerically. It also allows sorting in ascending and descending order.
Any data file with accompanying metadata.
The order of the metadata is changed in accordance with the rules set forth in the task's properties.
The original data file is output, along with the modified metadata.
For each parameter, three columns are available: Sort By, Then by, Then by (again). This lets you sort your document level in three different orders sequentially. Sorts are always done from left to right, top to bottom, giving you a total of 9 sorting possibilities.
When you click on either of the sort boxes, a small popup displays the following options:
Common Errors
Comments Tab
