8.17.52015-05-05
Laserfiche Repository Output
Laserfiche Repository Output task publishes files - and optionally sets index values - into a Laserfiche server. This task uploads any documents in a Laserfiche repository, optionally filling the index information on the Laserfiche server with dynamic information that can be taken from PlanetPress Suite PDI files (for PlanetPress Suite archives only).
The Laserfiche Repository Output requiresthe Laserfiche Runtime version 8.1 or higher and will not work with previous versions. It also requires a valid PlanetPress licence.
Laserfiche is a provider of digital document and records management systems. Laserfiche has two components: the Laserfiche server, which hosts the repository, and the Laserfiche client, which serves as the user’s interface with the repository.
Any file that is compatible with Laserfiche (see the Laserfiche user manual for more information on supported files types)
A connection is established with the Laserfiche server, the file is uploaded and the metadata in the Laserfiche server is generated correctly.
The output from this task is the specified file along with the metadata within the Laserfiche server. The file is not directly modified by this task.
Task Properties
Connection Tab
Common Errors
Comments Tab
Restrictions
