8.17.52015-05-05
Capture Fields Generator
The Capture Fields Generator Action Task is used to generate Capture patterns in your job, which will then be printed for use with an Anoto Digital Pen. It also interacts with the Capture database and does some operations.
PlanetPress Capture Fields cannot simply be inserted into an existing document as-is and expected to work properly, efficiently or consistently. In order to design a document with Capture Fields, you must review and understand the Critical PlanetPress Capture Implementation Restrictions.
The Capture Field Generator Action Task expects to receive a regular data file that corresponds to the Capture-Ready document that uses it, along with Metadata generated using the same data file and document. This means that this task must be preceded by at least the Create Metadata task.
This metadata must also be correctly separated at the Documents level, either in the Capture-Ready document's properties or through the Metadata Level Creator.
You may also use a Metadata Sequencer in order to split the job into multiple parts. This both creates multiple smaller outputs, as well as multiple smaller PDFs in the Capture Database. While it is not recommended to separate each document on its own as it removes all optimization and makes the database much larger, you may split into document batches such as 250, 1000 or 2500 documents.
If using the Metadata Sequencer it is generally recommended to place the Sequencer and the Capture Field Generator tasks within a branch and, within the Capture Field Generator's On Error properties tab, to set it to stop the branch if any errors occur. This is to ensure that if such an error occurs most of your document sequences will get generated and you will not have to start the job over from the beginning.
The Capture Fields Generator Action Task uses an existing PlanetPress Design document containing Capture Fields and assigns a unique Capture Pattern to each printed page. The task then locks each pattern that it used so it cannot be reassigned to any other document.
The whole job is then converted into a PDF file which is stored, without the patterns, in the Capture Database. This PDF file is later used by the Capture Fields Processor to be merged with ink from the pen. At the same time the output is generated, either as a PDF (including the patterns) or an Optimized PostScript Stream file. This means that regardless of the output, a PDF is always generated in the database.
If any error occurs during processing, such as running out of patterns while generating the job, every action made by this task will be rolled back as if they hadn't happened.
The Capture field Generator action Task will output either a PDF and Metadata, or an Optimized PostScript Stream file without Metadata.
Properties
Pattern Generator action task properties are as follows:
Examples & Use Cases
Common Errors
Comments Tab
"Anoto" and the Anoto logotype are trademarks owned by Anoto AB. PLANETPRESS CAPTURE is based on Anoto Digital Pen and Paper Technology, which is covered by over 200 patents worldwide, including but not limited to US6663008, US7172131, US7248250, US7281668, JP3872498, JP3842283, CN1595440, SE517445, RU2256225, and AU773011.
