8.17.52015-05-05
PlanetPress Capture Pen Management Tool
The Pen Management Tool screen is used to manage the pens that are registered in the PlanetPress Capture Database. The number of Anoto Digital Pens you may register on this screen depends on the licenses available within your PlanetPress Capture License.
This window has the following options and controls:
To register a new pen manually
  1. Click on the  icon
  2. Enter the Pen ID (located on the pen after the word "Serial: ")
  3. If necessary, enter an optional pattern sequence and User ID (identifier of who will use the pen).
To register a pen using the registration pattern
  1. Click on the Print pen activation file button in the top toolbar of this dialog.
  2. Use the Windows Print dialog to print to the desired printer.
  3. Write or make a line on the printed pattern.
  4. Dock the pen in its cradle.
  5. Click on the Read PGC File button in the top toolbar of this dialog.
  6. If necessary, enter an optional pattern sequence and User ID for each pen.
Multiple pens can be registered at once simply by writing on the registration pattern and then docking each pen before clicking the Read PGC file button.
If the pen that is being registered already exists in the pen database, the "Replace User ID (Description) dialog appears, with the following options:
