8.17.52015-05-05
Input from SharePoint
The Input from SharePoint Task can be used to retrieve files from a SharePoint server on your network, filtering on your template fields and creating metadata to use in your process.
When the Input from SharePoint task runs, it first lists all of the files to download then runs the process once for each file in the list. If any new files are added during the process, they will not be touched until the next time the process is scheduled.
This task can work with many of the available SharePoint servers:
Any data file present on a SharePoint document store, even those not compatible with PlanetPress' emulations, and the properties of these files.
The task connects to the selected Document store and retrieves a copy of files according to the specified rules. The files may be deleted or marked as checked out depending on the options selected, otherwise they are untouched.
The output to this task is a series of individual files, one after the other.
The Input from SharePoint Task has the following properties:
For this tab to work, you must have entered your SharePoint Connection information in the Connection Tab.
Connection Tab
"Other" Tab
Job Information definitions
Common Errors
Comments Tab
