8.18/6/2018
Adding Tasks
You can add as many tasks as you want to your process by using the Plug-in Bar in PlanetPress Workflow program.
To insert a task:
  1. Open the Plug-in Bar by clicking on its tab. If you can't see the Plug-in Bar tab, click on the View tab in the Ribbon and make sure the Plug-in Bar is highlighted in the Show/Hide section.
  2. Locate the task you want to add to your process. You can navigate between the different task categories by clicking the icons at the bottom of the Plug-in Bar.
  3. Using your mouse, click and drag the task in your process at the place you want to insert it.
  4. Depending on where you place your mouse, you may see that you can replace or insert existing tasks, or not place it at that location at all.
  5. When you drop the task in the desired location, a dialog box containing the available task properties is displayed.
  6. Set the task properties as required and click OK to close the dialog box.
There are a few things to keep in mind when dropping tasks:
