8.18/6/2018
Send to Folder
Send to Folder output tasks send the files they receive to a local folder. They perform the same function as Send to Folder action tasks, with the only difference being that in this case, PlanetPress Workflow will not wait for the task to be completed before going on to the next task in the configuration.
The following describes the properties specific to Send to Folder output tasks. For information on those properties shared by various types of tasks, such as Other and On error properties, refer to Configurations, Processes and Tasks.
Any data file.
The file is saved in the location specified, as the file name specified.
Task Properties
General tab
Common Errors
Comments Tab
