8.18/6/2018
Generic Splitter
The Generic splitter is a legacy task which is kept for backwards compatibility purpose. In previous versions of PlanetPress Workflow, it was the only splitter available. While this splitter seems to have more options than the other ones, this is only because it contains combined features from these other splitters.
The Generic splitter, while seemingly more feature-rich, is slower than the other splitters by an order of magnitude. Whenever encountering the Generic splitter, it is always recommended to replace it with a more appropriate splitter instead.
Any data file.
The file is separated into multiple chunks according to the rules set in the task's properties.
Multiple data files, sent one after the other to the rest of the tasks in the process. Metadata, job infos and user variables are not modified by this task.
Generic Splitter action task properties are as follows:
A Page Number: If you choose “A page number” in the Split data file on list box (the Use emulation option must be selected), the following boxes are displayed.
A Database Field Value: If you choose “A database value” in the Split data file on list box (the Use emulation option must be selected), the following box is displayed.
A Database Field Change: If you choose “A database field change” in the Split data file on list box (the Use emulation option must be selected), the following box is displayed.
Common Errors
Comments Tab
