8.18/6/2018
Decompress File(s)
Decompress action tasks decompress zipped job files (files compressed as zip files).
This task only accepts ZIP Files, however it is not necessary that the job file be the ZIP, since this file path and name can be specified in the task itself.
Every file in the ZIP is extracted to the specified location. If a folder structure exists in the ZIP, it is respected in the output folder.
This task outputs the data file it received with no modification. Metadata and job files are not touched either.
Decompress action task properties are as follows:
Common Errors
Comments Tab
