8.18/6/2018
Rename
Rename action tasks are used to rename the job files they receive. Note that you can see how each file is renamed via the Object Inspector when stepping through a process in Debug mode.
Any job file, in any format.
The task renames the job file to the desired name, and changes the value of %f and %F to reflect the new name.
The input data file is output, with the new name.
Rename action task property is as follows:
General tab
Common Errors
Comments Tab
