8.18/6/2018
Send Images to Printer
The Send Images to Printer Action Task is used to (obviously) send images to the printer so they can be used as resources by documents run on the printer. They are comparable to Download to Printer action tasks (see Download to Printer), but they include image specific options. Furthermore, they can be used to send images not only to printers, but also to the virtual drive of other computers running PlanetPress Suite applications. Note that each Sent Images to Printer action task must be followed by a Printer Queue output task set to "passthrough", in order for the images to be actually sent to that printer.
Images sent to a printer are stored in the root folder of the printer’s hard disk, while images sent to the virtual drive of another computer are stored in a sub-folder of the PlanetPress Workflow folder.
Any image file that you wish to upload to the printer.
The currently active image data file converted to postscript. The image's resolution, scan orientation, and quality can be modified, depending on the selected option. All files are converted into PostScript format for storage on the printer. If a virtual drive, the file is automatically sent to it.
A postscript file containing the necessary code to save the data file on the hard drive.
Send Images to Printer action task properties are as follows:
General tab
Common Errors
Comments Tab
