Add Set Job Infos and Variable action tasks to set job info elements as well as custom variables. You can set multiple variables and job info values in a single task. Be aware that lines are processed from top to bottom.
Any data file in any format.
This task assigns the defined values to each local or global variables or job informations. It does not modify the data file nor the metadata.
The original data file, metadata and job infos are not modified, they are passed on to the next task.
Set Job Infos and Variables action task properties are as follows:
General tab
button: Adds a new line and lets you define the variable and value to set.
button: Removes the line that is currently selected (highlighted).
button: Moves the line up so it is processed before.
button: Moves the line down so it is processed after.On Error Tab
By default, any action task, branch, splitter or condition that generates an error will simply be ignored, and the task just under it (not within a branch) will be given control of the job file without any modification. Any initial input task that generates an error will stop the process from running as a whole, and output tasks will not generate output. The On Error tab can be used to overwrite the default behaviors.
Common Errors
Comments Tab
The Comments tab, added in PlanetPress Suite 7.5, is common to all tasks. It contains a single text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in The Task Comments Pane.
