8.18/6/2018
Create PDF
The Create PDF Action task allows users running either PlanetPress Office or PlanetPress Production to create native PDF outputs without an active PlanetPress Imaging license. It very similar to the Digital Action task (see Digital Action) but is more limited. It does not contain the advanced PDF options that are offered by the PlanetPress Imaging solution, but is useful for creating simple PDF files using the default quality.
This feature is part of the PDF Tools, which is only available in PlanetPress Office and PlanetPress Production. It is not available with a PlanetPress Watch license.
PDFs created with the new Create PDF Action task will effectively replace the current data file in any given process using such a task.
Any data file supported by PlanetPress Suite.
In the case of regular data files, these files will need to be merged with a PlanetPress Design document.
In the case of a PDF data file, two things can happen. The PDF can be used as a data file for a Design document, or it can be part of a straight PDF workflow. When this is the case, this task will rather apply the active metadata to the PDF data file (see PDF Workflow for more information on this).
The output of this task is always, exclusively, a PDF file, optionally optimized and optionally with fresh metadata.
General tab
Common Errors
Comments Tab
Other Notes
Here's a list of the hard-coded PDF values for files generated with this new plugin. Basically, these settings correspond to Digital Action and PlanetPress Image settings for Standard Quality:
