8.18/6/2018
Create Metadata
Creates all the metadata that is either the result of the merging between a data file and a PlanetPress Design document, or the information about a PDF File.
Either a data file in any supported Emulation, or a PDF File.
If a data file and document are selected, the metadata is generated by merging the data file and document and retrieving only the metadata generated by this merge. The Metadata levels will reflect those defined in the document, including separation for Group and Document, metadata fields, etc.
If the "Do not use document (passthrough)" option is used, no PlanetPress Design document is used. The metadata will contain a single Job, Group and Document level, as many data page levels as there are records (pages in a PDF, XML levels, etc) in the file, and one page level per data page.
In PlanetPress Design, this step is equivalent to a &metamode variable value of 1.
The original data file is output, along with the newly generated metadata file. Job infos are not changed.
Task Properties
Examples & Use Cases
Common Errors
Comments Tab
