8.18/6/2018
The Message Area Pane
The Messages area is used in Debug mode to indicate the status of your PlanetPress Suite process as the sample data file is processed and used to generate output. When your PlanetPress Workflow runs in Debug mode, the Messages area displays useful processing and error information.
Messages are displayed in different colors (debug levels) in the Message area.
There are various actions you can execute in the Message area. Here they are:
The Message Area will only display information while running in Debug mode. It does not display information from other running services, and will not display the log of any process running in a live configuration (submitted to PlanetPress Workflow Service).
To learn more about debugging a process, refer to Debugging and Error Handling.
