8.18/6/2018
View Document Properties
PlanetPress Workflow Configuration programs let you view a number of the properties associated with the PlanetPress Design documents you use, but most of those properties are set in PlanetPress Design and cannot be edited using PlanetPress Workflow Configuration program.
The Document name of printer-resident documents can be changed using PlanetPress Workflow Configuration program simply because it is initially set using that program.
The properties available via the Printer Settings tab define how documents are printed. They are also set using PlanetPress Workflow Configuration program and are retained when documents are assigned to printer queues. They can be edited by selecting documents within the Documents category, which changes the document’s default printer settings, or within the Printer Queues category, which changes the document properties on the selected queue .
To view the properties of a document, do one of the following:
Document Properties Options
Identification Tab
The information here is read-only and gives you information on the document.
Printer Settings Tab
