8.18/6/2018
Metadata Filter
The task allows specifying the Level (Group, Document and Datapage) on which to perform the action and under which condition. At least one level must have the condition set. The action will be performed sequentially beginning with the rule on the Group level, Document level and Data page level. The selection is performed on the node only.
Any data file with accompanying metadata.
Any metadata that does not correspond to the rules set forth by the filter are removed from the active metadata. Note that the metadata is still "present", but is disabled and ignored on all tasks that uses metadata afterwards.
The original data file is output, along with the modified metadata.
Task Properties
Common Errors
Comments Tab
Special Considerations
