8.18/6/2018
Metadata Fields Management
The Metadata Fields Management task can be used to add new fields into your metadata, either for every element or through conditions.
This task will automatically "loop" through the metadata and repeat its action for each of your metadata's datapage. This task should not be placed after a Metadata Sequencer.
Any data file with accompanying metadata.
Fields are added, removed, modified, etc, according to the actions defined in the task properties. If the field is present in a level that repeats (for example, the data page level), this task loops so that the action may take place on each of the occurence of that level.
The original data file is output, along with the modified metadata.
Task Properties
General tab
Common Errors
Comments Tab
New Wild Card
For a given Metadata Field Management action, all nodes of a given level might be updated with a new Field Value. To accommodate this, metadata/data selection functions have been modified to accept a wild card parameter "?", indicating the function operates on all nodes (not just one) of a given level. For example, in a PDF emulation, the format of a selected region is:
region(?,0.59375,2.21875,1.85416,2.51041,KeepCase,NoTrim)
where “?” represents the current physical data page processed by the task.
Limitations
