8.18/6/2018
Microsoft® Word® Documents To PDF Conversion
The Microsoft® Word® to PDF Action Task can be used to convert a Word® document into a PDF file that can be used in your PlanetPress Workflow process. It can also do a Mail Merge as it runs the task.
This plugin is only available with PlanetPress Production (and not with PlanetPress Office or PlanetPress Watch).
Microsoft® Word® needs to be installed for this task to be functional and to test the connection.
A compatible Microsoft Word Document (see notes).
The Word document is converted into a PDF file. If a Mail Merge is made, the mail merge is done in the document before the document is converted into a PDF file. The conversion is done through the use of a printer queue - the document is printed to this queue and the print job is converted to PDF. This is the same technique used in the WinQueue Input when generating PDF files.
One of:
Task Properties
General tab
Common Errors
Comments Tab
Notes
