Calls and executes an external program through a specified command line. The program's execution will be directed by the appropriate flags specified as this method's parameters.
Syntax
Watch.ExecuteExternalProgram const CommandLine: WideString; const WorkingDir: WideString; ShowFlags: Integer;
WaitForTerminate: WordBool: integer;
const CommandLine:The command line to execute as a widestring.
const WorkingDir: The working directory for the execution of the command line as a widestring.
ShowFlags: Integer value representing the flag to use during the execution of the command line. These flags have an effect on the execution window opened by the ExecuteExternalProgram procedure.
Flag |
Effect |
| 0 | Hide the execution window. |
| 1 | Display the window normally. |
| 2 | Display the window minimized. |
| 3 | Display the window maximized. |
| 4 | Makes the window visible and brings it to the top, but does not make it the active window. |
WaitForTerminate: A boolean value that, if true, pauses the script until the command line has been fully executed.
Watch.ExecuteExternalProgram "lpr -S 192.168.100.001 -P auto c:\myfile.ps", "c:\", 0, true
Watch.ExecuteExternalProgram("lpr -S 192.168.100.001 -P auto c:\\myfile.ps", "c:\\", 0, true);
Watch.ExecuteExternalProgram("lpr -S 192.168.100.001 -P auto c:\\myfile.ps", "c:\\", 0, True)
$Watch->ExecuteExternalProgram("lpr -S 192.168.100.001 -P auto c:\myfile.ps", "c:\", 0, true);
