8.18/6/2018
Create Print Content
The Create Print Content task generates a set of printable content items from a template's Print Context, and saves those content items in the database until output creation is requested.
This task can receive either the information regarding a valid Record Set (which can be the output of the Create Record Set task, or a Record Set retrieved using the Retrieve Entities task) or a PDF/VT File.
In the case of a record set and template, this task loops through each record in the Record Set. For each record, an one or more pages are generated using the record's data and these pages are saved as a content item in the database. In the case of a PDF/VT file, content items are created based on the structure of the PDF/VT metadata and content items are stored using the data for each of those metadata records.
The output of this task is modified metadata with information about the job processing and each created content item. No content item is actually output from the task, they are only saved in the OL Connect Database.
Properties
The Create Print Content task properties are as follows:
Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs send through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences. Note that defaults are not used unless the configuration is sent to the Workflow service.
Common Errors
Comments Tab
