8.18/6/2018
Metadata File Management
The Metadata File Management Action Task is used to execute actions on Metadata files. This task does not modify the data, job infos, variables or any other part of your process.
Input:
This task takes any file as input and does not modify it.
Process:
This task does not execute any change to the process, its files or variables. It only executes the selected action on Metadata.
Output:
This task outputs the exact same data that was given to it. Its metadata will either be missing (Delete Metadata), Changed (Load Metadata) or the same (Save Metadata).
The Metadata Management Action Task properties are as follows:
Common Errors
Comments Tab
