8.18/6/2018
PDF Emulation
PDF Emulations allow you to capture data from fully composed documents in a PDF format.
PDF Emulation slightly differs from other PlanetPress Suite emulations: with other emulations, data is read either one line at a time or one character at a time, while PDF emulation processes the input data from the PDF file in such a fashion that every PDF page becomes a full data page. Each PDF page is thus graphically represented in the PlanetPress Design Data Pane as one data page.
Note that protected PDF and PDF of versions above 1.7 are not supported by PlanetPress Suite 7.
The PDF Emulation does not have any options - that is, there is nothing to set up when opening a PDF data file. PlanetPress Design simply reads each PDF file as a unique data page.
