8.18.12015-07-23
Standard Variables
Standard Variables, also known as "system variables", are variables that are created and managed directly by PlanetPress Workflow. Those variables are read-only and cannot be modified. They provide information about the job, process, and PlanetPress Workflow environment.
Available Standard Variables
Variable
Name
Example value when interpreted
%c
Content of your job file in its original format.
n/a
%F
Job File Path and Name
C:\Program Files\PlanetPress Suite 7\PlanetPress Watch\Spool\job1D80328.dat
%f
Job File Name including the file extension.
job1D80328.dat
%z
Job File Size in bytes.
34134
%o
Original File Name
invoice_june2nd.txt
%O
Original File Name Without Extension
invoice_june2nd
%y
Current Year
2010
%m
Current Month (numeric)
06
%M
Current Month (text)
June
%L
Current Month (short text)
JUN
%d
Current Day (numeric)
16
%D
Current Day (text)
Monday
%l
Current Day (short text)
MON
%h
Current Hour
18
%n
Current Minute
03
%s
Current Second
41
%v Current Millisecond 24
%u
Unique 13-char string (will be different every time it is used)
0ZIS4CW8U47VI00
%t
Current Temporary Folder
C:\Documents and Settings\All Users\Application Data\Objectif Lune\PlanetPress Suite 7\PlanetPress Watch\Spool\6.tmp\
%e
Current Metadata Filename
job00ZAIZ2C4FXON16CE6C566.dat.meta
%E
Current Metadata Path and Filename
C:\Documents and Settings\All Users\Application Data\Objectif Lune\PlanetPress Suite 7\PlanetPress Watch\Spool\5.tmp\job00ZAIZ2C4FXON16CE6C566.dat.meta
%w Current process name. My Process
%i Current Loop Iteration Index (always the innermost loop) 2
The %i Loop Count Variable
In version 7.4, the %i variable is introduced. Its value is equivalent to the current iteration of loops inside of a process. It always contains the value of the innermost loop, and only certain tasks trigger the counter to start. Here is an example process and the value of %i during this process:
Initial input tasks do not modify the value of %i. However, the following tasks do trigger the variable:
